2015 crf450 map switch not working
When i fire up the bike the map switch lights up once then goes off. I cant get it to switch maps or light up when i press it. Any ideas?
Dang nobody else huh?  Weird thing is the swtch tests fine. Could this be an ecm problem?  When i first start bike cold the switch lights up when i push it but doesn't change the mode. I tested switch with ohm meter and seems good. Tps set perfect. Idle speed at 1900. Bike runs great but would be nice to try other maps.
No idea. If it tests out ok and there's a proper connection to the harness it should work. Did you have the ECU remapped? Are you sure it's a 2015+ ECU and not a 2014 ECU???
I had one go bad on my 15 as well, not sure if it got wet from washing the bike or what but I had to replace one. May also check your idol (sp?), if you have your idol set to high the map switch won't change the mapping.
Yes its a 15. My friend bought it new. I bought it from him recently. I did try the idle etc. very wierd. Guess a new switch is next.
