2003kx65kawasaki whats the best oil to use for Kawasaki kx65
I have a Kawasaki kx65 2003  2 stroke with water coolant and power bands what is the best oil to use for it and the clutch
Idk  all I kno is it is a 2003 2 stroke kx65 with 7 gears clutch
If you have purple power bands use canola , if you have red/pink peanut oil seems to be the crispiest . Use gear lube for gear 7 and hold on those things are no joke in 7th .
Hey Eric. If you think you'll ride it hard then I recommend some Maxima 927 premix oil at 32:1 ratio. It's castor based for supreme protection and smells awesome too. No joke. Pistons will last for ages and even mum and dad will love the smell.
In the transmission you don't have to be too fussy. Any 2 stroke gear oil is fine. Or you can use diesel truck motor oil such as shell Rotella or Castrol Delo 400. Another option is cheap auto transmission fluid (ATF) but it should be type F so your clutch won't slip too much.
