Throttle arm stuck, crf250 2005 carburator problem
Today I decided to clean the carburator of my crf250r 2005. It was my second time doing it. When I opened up the top of the carburator to remove the slide, I didn't remove the throttle shaft screw and I still slid the slide out, but the control arm is now stuck. This video explain what I should have done at about 1:00. The only difference is I didn't remove the throttle shaft screw and now the control arm is sutck up and I can't slide it back down with the slide. I was still able to remove the slide. Anyone knows how to fix this? I can't acces the throttle shaft screw anymore since the control arm is stuck up.
Adding some pictures of my carburetor, scroll down for 2nd post to have them straight
Edited by alwaysonbalan
fixing photos
6 hours ago, alwaysonbalan said:
Fixed, something was blocking the shaft on the side with the throttle wheel
yeah happened to me few years ago , you are missing the stopper screw on the throttle wheel  , thats why you where able to remove slide with out removing throttle shaft screw .
The throttle wheel catches on the arm for the accelerator pump. All you gotta do is turn the wheel a little bit more like your opening the throttle, and then push on the pump arm. Itll pop right back down into place.
Just a theory, but I think honda maybe did this purposely for easy excess to the needle jet?
