Fuel/pilot screw on CRF125
  • 4 months later...
yes.  on the front of the carb...a short post that runs up and down.  The screw is inside the post.  You a perfect length screw driver to get in there unless the carb is removed.  Also the screw is a "D" shaped head so you will need the right driver.  If remove it while the carb is off you can cut a small slot in it for future use with the flathead screwdriver.
