2015 FC 350 wont start
My fc 350 wont start. I rode 2 days ago, ran good, show up to race today and wont even start being pulled behind a pickup.
I have had my main [10amp] fuse go out a month ago and I checked that..
Ever since that fuse, my starting has been hit and miss. Sometimes cranking long time to start. I know my battery is good. I got one out of new gas gas.
My plan of attack will be
Charge battery,
check my starter & kill switch. [remove kill & try starting]
Then search manual for any more vital fuses.
Check spark plug [but they're always calculated so why foul?]
I need help. Any suggestions help.
Thanks
FIX: a wire was rubbing raw&thru under my seat, against the top of voltage regulator. Striped & reconnected. Rips again
check on routing of the plug, there was a issue with some of the bike having the wire ran the wrong way and rubbing/breaking wire off
found the thread
