Yz250 linkage
I do not know the length of the various linkage pieces, but the parts list shows that...
...the relay arm has been the same from 2005 to current.
http://www.partzilla.com/parts/detail/yamaha/YP-1C3-2217A-00-00.html
...the connecting rod (dog bone) has been the same from 2006 to current.
http://www.partzilla.com/parts/detail/yamaha/YP-1C3-2217F-50-00.html
Good luck, and keep us informed with what you find. :thumbsup:
The first pic is
top stock yz450 14' linkage
middle yz250 stock linkage
Bottom yz450 14' pro circuit linkage
all the other pics are comparison of the yz250 stock linkage and 2014 yz450 procircuit linkage
Okay, cool. The "1C3" stamped into the dog bone is a YZ 2-stroke part. The "33D" means it's a 2014 450F part.
http://www.partzilla.com/parts/detail/yamaha/YP-33D-2217F-00-00.html
Are you considering running the 450 dog bone on your YZ? There is a thread here somewhere where a guy did some linkage swaps and recorded the various dimensions of the parts and their effect on the suspension. I think it's the '09 4-stroke swingarm swap thread...
I just wanted to use the pc link on the 250 if it was the same but didn't want to shorten or lengthen the stroke of the shock by changes the linkage I just need to know what the length of the stock yz250 linkage is I know what the pc length is
I don't know how accurate these measurements are but I know the pc linkage is suppose to be 143.5
I cannot believe after over a decade there is not a single site that has the true measurements of this part
I did a little searching through the forum and found this...
i will try to figure out how to do the picture thing on here. because that sure would be easier. the dogbone length from the centers of the pivot holes is 145mm.
Being the 250 two stroke comes with the 145 link, I wonder if thats what should be in place with the 09 arm? Talking two stroke here.
It sound like the 2-stroke dogbone is 145mm long.
145 sounds about right when I did the measurements I got 144.5 but 145 sounds better ! Thank you all
