2000 CR250 Reed Boot replacement
I need the boot between the reed valve and the carb.  It shows discontinued from Honda.  Are there any other years that will fit?  Mine is in bad shape and I need to find a new one.  I also looks like the previous owner cut the boot flat on the side that faces the reed.
14 hours ago, shrubitup said:
97-01 should be similar.
I ordered a 99 boot I found in Feebay.  I'll report back how it works.  Different part number, but I know the reed side is the same.  I'm guessing a slight boot angle difference.
I can send you a minorly FUBARRED one from a husky wr300. Same bolt pattern but has notably different carb alignment due to non perimeter frame. Free plus $10 shipping.
I may take you up on that if this 99 one doesn't work.  Thanks man!
