XR400 fork brace worthwhile ?
is a fork brace a worthwhile mod to an xr400 ?
i see now where it fits - is clogging with mud ever a problem ?
Edited by FFMan
I have the SRC fork brace, would definitely recommend it.
Not sure if you can find those any more, but super brace still makes fork braces for the XR.
The SRC is what I put on mine several years ago. It was discontinued along time ago. The Superbrace is probably the most available unit today.
Turned the spindly, deflecting XR forks into Trail Terminators.
i've bought one now off ebay so i'll let you know how i get on
16 hours ago, notoriousE-R-I-C said:
It'd have to be steel
more worried about small piece of wood between the tire and brace causing  unwanted braking of the frt.tire at the wrong time.lots of small sticks here in the nw
1 hour ago, Firestone said:
They should do different things. You cannot Grind ruts with precision with a damper and no brace. Believe me I've tried.
I would agree. I look at it like, a steering damper controls undesirable movement in the steering due to forces introduced by the terrain. A brace improves tracking of the front end and helps the front end resist those forces introduced by terrain "before" it effects steering.
