Some doubts
Having some troubles with an old bike.. I running the last night and after arrive at home I shut off the bike. And the next morning won't start
Check the spark and looks blue I think is good
Clean the carb
Put a new top end
Not luck
I put 4th gear and pushed the bike with a friend and bike starts but won't idle and smoke a lot
An air leak or bad seal on stator side I don't think on clutch side cuz oil level are the same
Electrical issue? Carb?
I've changed the cdi and do the same think
Bike are yamaha dt
Replace both crankshaft seals if it's a two stroke.  One will leak air behind the stator and the other will suck oil into the cylinder.  Do those and report back.
