The New Competition
You won't be able to sleep for months on end.
My Favorite tune... tried to Shazam it and down load but Shazam does not recognize?
5 hours ago, stevethe said:
You have been warned.
I understand that is a pretty good engine but why add more moving parts?  There is no doubt a shim-under-bucket valvetrain is great for high revs but there is no need in our context.  One of the things I love about our engine platform is simplicity and compact size.
But is it available in the USA....
I need to find out the wrist pin and the Bore size....
My contact as Wiseco has been very helpful to me over the years.  Not only did he get oversize pistons added to CRF230 offering in USA he also worked with me on SRX600 piston.  He is now working to see if they have a match for an old SRX250 piston for a fellow rider.  He created an RMA and I had the SRX250 owner send the piston directly to him.  So far it has been very good working with this company.
I should also note Wossner has been very helpful to me as well.  Kind of surprising given the small market these bikes fall in...
What's Wiseco's explanation for an 11:1 piston being only 10:1 ?
It's much easier to shave a piston down than to add . . . .
1 hour ago, stevethe said:
For the big bore watercooled bikes I don't like Wiesco Pistons. They spec out clearences that you would call for in worn out parts.
I'm running .0007 in Yamaha 450's with J.E. pistons.
Should I slip a high compression JE in my 230 with less than 200 miles on factory bore?
2 hours ago, Baja Rambler said:
What's Wiseco 's explanation for an 11:1 piston being only 10:1 ?
According to Wiseco on 01/26/2015:
"Ok, the baseline value for the CRF230F was a measured 9:1 CR using the stock piston, .020” deck, and .020” gasket. Our dome brings the engine up to an honest 10.8:1 CR. So provided your seeing these deck numbers, and the head is 25cc volume, you should be netting this CR statically. I guess I am not too surprised if your measuring less, so take away .3 CR points and our part will be 10.5:1, everything being the same."
Since we know our deck and head gaskets are actually thicker we no longer get 10.8:1.  Perhaps when Wiseco designed this piston the early CRF230s had tighter tolerances and/or different dimensions.
I can only assume Wossner's "11:1" piston design suffered same or similar consequences.
Edited by VortecCPI
.030 deck with .043 gasket....all that I have ever seen...
4 or 6 mm stroker takes care of that.
Terry can get your engine to a nice .038 deck with any piston or gasket combination you desire.
