1991 kx 80 bottom end (HELP)
hey guys, first post but i need some help on the bottom end of my kx 80 picked it up of craigslist... good price but needed a full rebuild. can anyone help with the fact that i have the motor apart and everthing neatly aranged. now everthing replaced good to go. stuck a little on the re sealing this bottom end. is it ok if i use just black rtv on the case. instead of doing a cosmetic bottom end gasket kit. i would just use rtv and seal it like that. would that be ok or do i really need the paper gaskets.
thanks alot any info will help :rolleyes:
Paper gaskets are cheap...it is weelllllll worth it to wait for it...don't want to take a risk of a leak of rtv! If it leaks you have to split the case again and that is never fun! So spend the money and wait for the proper gasket to come you will be much happier!
thanks man wasnt really sure on if i could use the rtv its like a 30$ gasket kit(super cheap) i just didnt want to wait it out & wasnt sure.. thanks for the time
