2001 drz 400e carb leaking gas while not running
My 2001 drz 400e is leaking gas while turned off but when running no gas leaks from the overflow tube off the carb. I opened the carb and cleaned the jets, checked the float and gasket. From reading other posts I see that the fuel petcock may be a possible cause, what other things should I check or is this the petcock?
