My bike is overheating on 10 minutes of it being on. It backfires and pops I think the muffler needs to be repacked. Could that be the issue? And the coolant leaks I'll attach a photo where it leaks
You need to determine if the leak is causing a low enough coolant condition, and that is casing it to overheat, or do you have an overheating problem, and a coolant leak too.
The pooping and backfiring may be an exhaust leak where the pipe meets the head; and you may not necessarily hear it.
Take a 12mm wrench, and carefully snug the 2 nuts up if they are loose.  DON'T BREAK THEM OFF.
Edited by WALKINGWOUNDED
