Piston doesn't fit cylinder
Hi,
I just opened my 99' CR250R top engine and removed the old Wiseco piston.
When i put the new Wiseco piston inside the cylinder it wont go through smoothly. It gets stuck in the middle...
How could it be if the new piston i bought is a standard bore piston and not for an oversized cylinder?
BTW I prepared the cylinder before installation by doing honing.
Thanks
Time to breakout the micrometer and bore gauge.  Always measure before installing so you know it's the correct size.
