Honda CR250 - Engine Rebuild
Hi All,
Rebuilding a 2001 CR250R, lower end and top end.  I split the cases, new crankshaft, all new bearings, etc.
Question:  Honda uses a center case gasket and Yamaha does not.  The Yamaha rebuild has proven solid with the YamaBond gasket product.  I got ahead of myself and forgot to put the bearing stays on the tranny bearings, which are inside the engine.  When I split cases (again) to install tranny bearing stays, the center case gasket was destroyed.  So, has anyone ever used the YamaBond "form a gasket" product on a Honda rebuild instead of a gasket?
I know I can order another case gasket cheap, but I'll have to wait about a week to finish this rebuild...  I'm getting impatient.
Thanks in advance.
