05 yz450f WILL NOT START
Wow guys, I'm clueless at this point.
I have an 05 yz450f that I got not long ago. Was running fine, started doing minor stuff to it. (Levers, chain & sprockets, hot start cable, etc.)
Reshimmed the valves to put them back into spec and it ran fine. Took it to a track and ran fine. All of a sudden, 1 week later, it doesn't want to start at all. I've completed a carb rebuild and have gone through the carb 3 times as of this afternoon. No leaks or anything. Put a new hot start cap on it to make sure it's not an air leak from there. The timing is still in. I checked.
It will get a little froggy and back fire every couple of kicks, but it WILL NOT START! Even have a brand new spark plug. It has a great turn over sound and is just at the cusp of firing off, but no cigar. I'm out of ideas
Clear the cylinder and start over
Wide open throttle and kill button at the same time, kick a dozen times.
Then start as normal but turn the idle in 1/2 turn first. Start with no throttle but the choke on.
