Pipe choices
Anyone know if there is a difference between the fmf fatty and the factory fmf Husqvarna pipe outside the "factory" pipe havung the husky logo?
3 hours ago, 95jersey said:
Not the same pipe at all
Any ideas what the difference is? Im pretty happy with the power delivery of the stock pipe. Just need a bit more dent resistance. Im quite certain i dont want a gnarly, I wouldn't mind the durability of it though.
Check out SRT oem replacement pipes. They are thicker steel then stock. I haven't tried them, but have heard good things. Nice price at $159.
Link: http://www.srtoffroad.com/node/112
No better dent resistance.  Get a pipe guard.
They don't list a pipe for the 17 yet.
Thicker steel will be harder to dent.
Only Gnarly is thicker and you said you didn't want that...
I know the husky branded one is thicker than stock. The description includes that. I'm also fairly sure all the f2f pipes are thicker than stock.
The set pipes look like a food option with 19 gauge steel, if they have them for a 17.
3 hours ago, motodr441 said:
bat if u want to avoid denting you better get a guard
Not a huge fan of the carbon pipe guards and I bought a light bike for a reason.
I'm curious if SRT has pipes for the 2017, but maybe they haven't updated their website?
Try giving them a call. If you do, let us know what they say.
I personally went with a Pro Circuit Pipe and like it, but have a RK Tek head and VR4 reeds.
And yes I have put little dimple dents in the PC Pipe already. When ever I get a big dent I will pull the PC Pipe off and put the stock Pipe back while I blow out and fix the PC Pipe.
It's pretty easy to fix dents in a pipes with rubber plugs for both ends and one with a valve stem to pressurize the pipe and a butane torch to heat it up. The dents come right out.
Just make sure that you have the rubber plugs safety wired. They can blow out at a high rate of speed.
Just got a return Email from srt, they should have a pipe for the 17 soon.
