Reed intake flange crack
I noticed recently that my reed intake flange has some minor weathering cracks in the rubber. Could it be possible that I have a slight air leak? How can I tell? Propane test..? Thank you for your help. IMG_20170520_191520.jpgIMG_20170520_191509.jpg
Lean running will mean the bike might detonate under full-throttle when pulling from low to mid-revs.
Also, as the revs come down, the idle might hunt ... like high-low-high-low or just be higher than before.
  • Like 2
Use yamabond for center cases it will work good till you get new one
Geez... I have had trouble under full throttle... Being new, I have not been able to diagnose it. The bike will scream up top but have almost no pull.
Detonation? I'll stay off the bike for now until I can replace that flange.
I have a good used one for a 250SX/xc/xcw. Send me a private message if you're interested and I can let you know what it will cost to ship.
common KTM problem. Cracks rarely make it all the way through.
Yes, they rarely do. I removed my flange and saw nothing. I will likely still touch the rubber up with Yamabond or silicone to prevent them from worsening.
This. I recently spotted a crack on my 2007 250 XC. I hit it with some WD-40 while running to test, not all the way through, but I have another one on the way.
