Yz85 clutch stuck. Help
So I'm replacing the clutch on my wife's yz85. It's my first clutch. I believe I've got it put back together properly but the clutch won't return on it's own after you pull the lever. I have to manually push the lever on the crank to disengage it. Any ideas what I'm doing wrong? It's a tusk kit  if it matters. Thanks. Hoping to get it back together for a ride tomorrow.
Unless it was apart a long time it almost has to be a binding issue when you bolted it back down or the wrong springs or clutches
I'm pretty sure you were right. I ended up doing about one quarter turn per bolt and it worked. I didn't realize it was that sensitive, even a half turn was too much.
