Gpx 125/150 crankshaft
Ok guys i am woundering if the gpx 125cc crankshaft is the same as the gpx 150 crankshaft. The crank has snapped on my 150 right between the timing chain gear and the main bearing of the casing. I have a good running gpx 125 and i want to use the crank if it will work
