Fuel line location/function
Which lines go where? Ie vents and main fuel line (feeding carb) it came in pieces so just making sure. Haven't seen anything anywhere online. Is the one on the left side faceing down a vent overflow line and tje one facing forward on tje left side the main line? Thanks!
Ah yeah, 2000 klx 300r
If you go to one of the parts houses (I use Bike Bandit) and pull up the carb diagram it shows the locations and the dimensions of the various hoses. Not the easiest to use but can be done. Main fuel line will be pretty obvious when you match the tank outlet to the carb. The one facing forward is the inlet for the carb.
