no dampening after shock rebuild, help a suspension dummy!
Just put new seal and oil in xr400r rear shock. Seemed straightforward,used rmatv tutorial video. I dont have nitrogen filled yet,but shouldnt it have dampening already? Put shock back on bike,waiting for a nitrogen regulator to be delivered,so i put 75 psi of compressed air in shock,just to see how it felt,No dampening no matter where i move upper or lower rebound valves/screws. Any idea,i am sure valve stack is in correctly,slid whole set onto screwdriver,left them there til reassembly???
As soon as you pour oil in you have some damping.  Unless the shock is dramatically underfilled I suspect there is something wrong with the way it went back together.
Did you put your piston/valve on backwards?
Pop it apart again and post a pic of your piston/shim assembly.
picture shim stack on rod,with spacer i made to shorten stroke above it. Trying to lower seat height by adding .700 thick spacer on rod. 1.8" lower rear wheel,im old!
just had it pointed out this is a race tech gold valve,I had no idea it was changed by previous owner. It takes special lowering washer/spacers which have triangle shaped holes in center,and grooves cut in faces to help oil flow,i assume. Will call racetech tomorrow and find out,and also what weight oil to use.
Silly question maybe, but did you install the band/ring?
this thing
Edited by DEATH_INC.
Is that a gap between the rebound shim and the piston edge ?
That spacer going to scratch the shaft ?
this thing
that band is not in my shock,was none in there when i took it apart???? Holy shit,my forks worked pretty well,i thought. I definitely have to call racetech today to check,as well i would guess ill find gold in front forks too. Didnt want to touch front til back was finished,wondering if i can find previous owners name and ask him,he sold to the guy i got it from,used to live in colorado. Lives in south east ma. or rhode island now,not sure.that band would definitely make a difference! Death,if you could pm the instructions,it would be great,not sure how it is to deal with race tech.
called race tech,nice guys! ordered 2 piston bands and set of lowering washers,and emailing me original gold valve instructions,GREAT GUYS to deal with,didnt expect that,Thanks Brad at race tech!
  • Like 2
