2017 500 EXC changing rear sprocket....stock chain?
Stock gearing on my 500 is 14/45.  Going to put a 50t on the rear...think the stock chain will fit or should I grab another at the same time as the sprocket??  Thanks
I put a 48t on mine and it seemed like a 50 may fit. Curious what everyone else else says. A 48t is really sensitive in 1st on rocky terrain, barely usable. I am not planning to put a 50t on mine, we will see as I get more used to the bike.
I have a 17 500 EXC I put a 50 on the rear and had to get a chain.
14-50 new chain or 13-45 stock chain . ratio hare close . 13-45 is faster but close
Why not just install another master link to extend the chain? Wear out the chain and then buy a longer one.
Edited by Skip Wareham
the chain is only as strong as its weakest link why double the odds
An extra master link does not give you another link of chain. It is the two outer plates, you still need the inner link.
On 5/26/2017 at 11:44 PM, Airboss/oc said:
best offroad combo is 52/14
^^^So true!^^^
with 119 link chain you can 13/52, 14/52, and I believe I can 15/52 if I ever wanted to.
14/52 can cruise very conservative at 60mph with plenty of reserve.
