Suspension Set-up
Anybody know what weight rider the factory suspension is setup for on a 2013 WR450F. I'm 165lbs and I ride in New England where it's all loose rocks, mud, roots and tight trails. I'm looking for suggestions to stop my front end from washing out in berms and beating me up on technical trails with a lot of rocks. I don't want to go do my own thing with the click adjusters with out having a good base to start from so I don't get used to the wrong set up. Any help is appreciated thank you.
First set your sag to recommended setting...then make adjustments to clickers as per your results. Plenty of good reading material on the web to help dial you in.
