fork-mount turn signal mounts
Any suggestions for a decent front turn-signal fork-mount?  It's for dual-sport if that makes any difference (not for supermotard).  I want to mount the bark busters to the fork, and the recessed bolts on that adapter won't allow for the stock turn-signal mount.
Make your own aluminum mounting brackets or you can obtain various configurations made by DRC Hardware in their Moto-Led line.Wheeling Cycle Supply carries them.You can scroll thru and see which ones will work for your application but I just made my own from 1/8" thick aluminum then painted to match and bolted to the side of my front forks for a factory appearance.
i bought 4 led light ($4 each) that i mounted in the handguard. and added 2 small turn signal in place of the reflector.
I'm glad Texas doesn't require turn signals. Mine are in a box.
  • Like 2
lol, i actually want to be seen. ill probably add a few more....lol
