ttr 125 top end !!!!HELP!!!!
Ok... so I'm new to this forum. So if there is already a discussion of this, a link would be appreciated. Anyways... my question. I have an 07 ttr125l, I need a top end kit. Every one I find only goes up to an 05. Will an 05 top fit on an 07 bottom?? And any links to a kit would be great. Thanks guys and gals. God bless. Much love from the Sip.
I would just go  with OEM for piston and rings.  Check partzilla.com - around $100 for a set.  Then add aftermarket gasket set.
If you intend to go cheap with Chinese kit then I would check OEM part numbers for 2004 compared to 2007 and see if they are the same.  That will tell you if the kit should work.
