17 fe 501 LED signals are 4-way flashing
I used the tusk brand flasher relay, flush mount rears and the hand guard signals and I'm getting a 4 way flash when I turn my signals on. I removed the indicator bulb and even tried reversing the relay to see if that was the issue. No dice! Any help is much appreciated my buddy just bought his 501 and is itching to get out this weekend.
I spliced the OEM plug to the led signal wire to keep things clean. But I don't think that could be the issue.
Well I figured it out! The rubber grommet that held the leads to the bulb were still in contact so i clipped the end off and taped it. All good!
I'd like to have the indicator light back but I'm not sure how I'd make the blinkers independent of each other!?
