Still no compression after new rings
So I'm rebuilding the top end of my bike after it stopped running (03TTR 125L)
-I just put in new piston rings
-I got a tusk gasket kit installed those
-new spark plug (it gets a spark)
-The cylinder is perfect no scratches
-New petcock (old one only worked on reserve)
-Everything is torqued to spec
I think I got a small amount of water in the engine when I was cleaning it today, I covered the intake and exhaust with rags. The bike has low compression​ low enough that I can push it down with my hand.............................any suggestions????
Bad valves
Incorrect cam timing.
Rings installed wrong
Leaking head gasket (warped head/barrel/'pulled stud')
Thanks a lot I'll check em all
