BUBBLING IN RADIATOR WR250F
WR250F 2001
I had coolant leaking from water pump weep hole so replaced w/pump seal and no more leak. However after refilling coolant and burping air out of system I notice there is now bubbling in the radiator that increases when revs increase. It would seem to point to head gasket but before I pull the head off I'm wondering if there is anything it could be apart from blown head gasket? Thanks
Edited by PJNZ
Sure it's Not Just circulating? If there's a problem it will over heat and blow out over flow. Have you rode it at all to see if over heats?
Yeah, probably a head gasket. The leaking head gasket made the failing WP seal fail 'more'. Use a cooling system pressure tester and a stethoscope at the spark plug hole to listen for hissing, unless you have a bore scope to visually see the leak. A leak down tester will, also work, it'll loose pressure and you will see bubbles in the radiator.
Thanks for the feedback. If it was just coolant circulating then the amount of bubbling wouldn't increase so noticeably with higher revs would it?
