92 DR350SE
7 hours ago, GlennRay said:
How did you pull the seal?  I know I have done this before without splitting the case or even taking the engine out of the frame, but I can't remember how I got the seal out.
a small wood screw threaded partially in, pliers pulled it out
That is what I was thinking after I posted my reply.  It was the only thing that made sense.
4.2 gallon tank going on
this petcock will work
hose has a smooth path
made a copy of the lower support from 1/8" steel welding rod
bending jig
the clarke tank is from adammtb, petcock is a new yamaha  2GU-24500-02-00, free viton gasket material from brianpeck.
i trimmed the seat bracket corners, they were touching the tank.
had a drip from petcock to tank, used the viton to seal.
should have decent range now.
also pulled off the handlebar blocks & installed stock guards
  • Like 2
bending jig
So you made the lower support element out of welding rod to increase the strength/rigidty?
8 hours ago, plugeye said:
i made a copy of the wire because i only had 1 but have 3 tanks.
Makes perfect sense.  Nice bending jig by the way.
I wish I had that stock rear frame member/rack and the stock brake light assembly on my bike.  The rack I have is okay, but I'm not real fond of how the previous owner did the brake light/turn signals.
Is the kick stand on these bikes too short?
Nice thread Plugeye.
As I've noticed, you have a good collection of parts.
I'm in need of the plastic cases for the clocks.
Mine are pretty beat up as you can see in these photos. Can you assist, or anyone else w/ extras? G. 20180516_123851.jpg20180516_123746.jpg20180516_123754.jpg
sorry, i dont have any leads at the moment. i got lucky when someone got rid of his throwaways. between that and my pieces, i built a decent cluster.
try asking over on adventurerider.com/bikes/thumpers/dr350 thread also on maximum suzuki forum DR page.
best of luck.
Thanks a bunch for your reply.
I have a request on AdvRider fleemarket.
Going to register at
MaxZuk asap.
These items are almost as rare as chicken lips! G.
