Grease main and counter shaft bearing?
Replacing all the bearings and most of the tranny bearings come pre-packaged with grease but my main bearings and counter shaft bearing do not.
Is there a reason they don't have or don't need grease? Or should I pack them with grease? Thanks.
17 hours ago, BDubb106 said:
Just use a bit of assembly lube to install them, the engine oil will take care of the rest. Only the sealed bearings should need grease.
Thanks.
