2010 husky WR250 fork valving help needed
I am trying to improve my fork set up, I am new to playing around with valving so any help would be greatly appreciated.
I am 67kg with no gear on and the bike has done 24 hours so everything is in good shape internally.
I don't like the current set up is it is a little harsh with small bumps.
I was thinking of removing two of the 24mm shims, Dose anyone know if I am on the right track?
I am running 4.0 springs in the forks and a 5.2 in the shock, one rate softer than stock,  should I be considering a shim change for the softer spring rate as well?
I am keen to do whatever possible to make the forks and shock work the best they can.
Currently my comp valve stack is stock, see below.
24 .1
11 .3
18  1
18  1
18 .5
11 .25
13 .15
16 .15
18 .15
20 .15
22 .15
12 .1
24 .1
24 .1
24 .1
24 .1
24 .1
24 .1
I woukd try 3 just to prove the problem
