Pictures of Radiators/Shrouds 2003 200
I am trying to figure out why the shrouds have been modified on my 200.  It has radiator braces on it and on the outside of the braces another piece of black plastic.  I have nothing to compare to see if the plastic part is factory or part of the braces.  I will try to post a picture later.  The shrouds have been cut to allow room for this plastic piece apparently but it seems to fit poorly and i just want to simplify.
Thanks
9 hours ago, newstylecustoms said:
Ok, so I can't see why the shrouds were cut then. Do they usually require modification with braces?
It' seems probably because of the braces .
i put an after market set of radiators on a 200 and they are thicker then standard but I didn't cut the shrouds , it just took a bit of fiddling to fit the shrouds tho
Edited by kxrob
OK thanks for the info.  If I get new shrouds then I should not have to modify I hope.  They aren't destroyed yet but it won't take much
