PLEASE HELP CORROSION ON HEAD WORRIED !!
Ignore the gouges in the piston that was done after the corrosion of the head was found
That looks like detonation.
I bought a YZ125 that looked like that, the kid I bought it from was running a SST pipe on pump gas.
Eric Gorr said the result was from detonation, He turned it into a 144 for me.
Edited by Treesmacker
  • Like 3
I'm talking about the jug and head corrosion the marks in the piston are from me stabbing it when I found the corrosion
10 minutes ago, Alcorn859 said:
So what did I do wrong ? And how do I fix this ?
Retard timing or use Race Gas.
How do I get this fixed ? I was installing new piston when I discovered this... and decided to jam a flat blade screw driver in the piston when I saw it haha
Edited by Alcorn859
Head is cut ! And I only took this motor apart for inspection and found this corrosion I was using pure race gas.
30 minutes ago, Alcorn859 said:
Yes head is machined
is it a yz250? you previously had it machined for specific application (mx, offroad, gas type)? what is your timing set at?
For grins,  lift up the orings and take a pick and show them please.  what is your history with this engine?   Did you put the last piston in it?
