What should I check over / buy?
Now that I have brought my bike down to the house, I changed the oil, cleaned the air filter, cleaned and gapped the spark plug, lubed every single thing that moves.
So what else should I do, or check over? Anything I should buy, or any gadgets I should buy?
- check wheel bearings (if you havent)
- inspect throttle and brake cables
- change fork oil/ bleed fork
- change silencer packing
- run compression test
- clean carb for good measure
- give her a bubble bath and light some candles
- go ride
Skid plate, depending on the riding you do.
Im assuming you just bought it. Check where the suspension settings are on the forks and set back to stock if they are way off, set the sag on the rear as well. I would also suggest having an extra tube for each wheel on hand.
That is probably the number one best accessory you can buy for a bike.
Been riding it for a few months. Have 20hrs on it.
Made my own 🙂
Top off / replace the coolant, bleed the brakes.
Doesn't have a radiator.
