Forks from DRZ400S on DRZ400E
Is there any reason I should not try to install good condition front forks from a 2013 DRX400S (ebay) on my damaged 2004 DRZ400E? Maybe spring weight would be different? Anything else or mounting problem? Could not really be sure by comparing part numbers on BikeBandit and Suzuki PartsHouse.
They should be the same. If your current forks have been properly set up for you, you can always transfer the springs and valve stack to the replacement forks.
Yep if yours are stuffed and have been set up for you, shouldn't take much to swap valve stacks and springs. Once you've done it once it's easy.
