88 and 89 RM 250 Swingarms?
Anyone know if an 89 RM 250 swingarm will fit on an 88 RM250? I have what I believe is an 89 arm I just bought (seller stated it was from an 88) but side by side with what I removed and cracked, they are a bit different - linkage also. Just wondering if it will still work or if I should return. They look close but some width measurements are a bit different between the two.
Edited by rocket0322
addition
I cant say, but it just looks like they strengthened the one on the left. It has more metal in what I would think are the weaker points. also if it is tighter, it will be easier to support the load.
i think the frame attach width and shaft diameter are the critical areas, then axle and wheel fitment, I would run it if all attach points fit
