Doing a rebuild on a kx250f and have started on the shock. Got the spring off and was real smart by not pulling the damper adjuster prior to pulling the rod. Hopefully no damage done there. Started looking at the end of the rod. Does this look like it's bone stock? What tool do I use to unscrew the damper adjuster? It seems like it's in there pretty good.
No that's been apart before, what are you wanting to do with the rebound ?
All I was wanting to do it check the seals and replace if needed. So the previous owner took the nut off? Anyone have a picture of a rod that hasn't been filed?
I'm trying to take the compression adjuster out of the shock body. Don't know what size wrench.
Edited by Pastmyprime214
