2005 CR250R Transmission issues! Please help!
I recently bought this very clean 2005 CR250R.  After a couple rides I found it popped out of first gear.  I split the cases and found that first gear and the fork was worn and it was because someone was in the case before and forgot the thrust washer between first gear and the bearing.  I put it all back together and is seemed to shift fine.  Once the motor was back together, I set the shift drum and stopper up and I CANNOT FIND NEUTRAL.  Overall the shifting doesn't feel very sharp and neutral is impossible.  One thing that seem very weird is the location of the grove on the shift drum.  Is the mark supposed to be neutral?  What did I do wrong.  Any help appreciated.  I refuse to bring it to a shop and pay to have someone figure this out.  Thanks!
