Rear brake pedal rubbing Hinson clutch cover?
Just bought my first bike 2009 rmz450, it came with a Hinson clutch cover and I believe a tusk rear brake pedal and it is rubbing on the bottom front section of the clutch cover.
Is my peddle bent or is this just the set up or what do you think?
Thanks in advance.........
adam
It's possible it could be bent, but you can also adjust it, look for the adjustment nut on the rear master cylinder, right above the rear brake Clevis. You can adjust it to make the pedal go up and down. Depending on how much it's rubbing you could just bend the pedal a smidge.
