1999 kx250 expansion chamber differences.
Does anyone know the actual differences between the stock chamber and the FMF gnarly? Advantages or disadvantages? Or if anyone has ran different pipes and has any helpful findings. Thanks.
Gnarly shifts the power down lower in the rev range
So is the stock chamber better overall for the entire Power Band? Or does it still sign off early on top?
Better overall in my opinion.  Will have a lot more on top than a gnarly.  You'll have the bike to see if its got enough top end for you.  Those motors run best in the low-mid range.  The top end is pretty good but in stock form its mostly tuned for midrange thrust.
Ok thanks for all the responses. I appreciate the help.
wish i could try a stock pipe one day , i bought my bike with the gnarly already on it , i do like how it tractors along low in the rev range tho
Do you think there would be any jetting changes needed going from a gnarly to a stock pipe?
doubt it , if anything maybe an air screw adjustment
what jetting you got in the bike now ?
Year: 1999
Model : KX250
Displacement (cc): 250cc
Carb size (38 or 36mm): PWK38S (stock)
Slide: #7
Main jet: 155
Pilot Jet: 45
Air screw (turns out): 1 1/8 winter 1 1/2 summer
Needle model/Clip position: n3wk 3rd position
Altitude where you ride: 0-800 ft Michigan
Temperature: winter ( winter (50f) /summer (95 f)
Reeds: boyesen power reeds stock cage
Pipe/silencer: fmf  gnarly / fmf turbine core
Head mod: stock
Other mods: #58 power jet
Type of fuel: 93 octane 32:1 honda HP2 (I had a whole case left from last bike, dont judge!)
Where in the powerband do you ride (Lugger - for technical stuff, or wide open - desert / MX): 50/50 bottom and top
Degree of satisfaction: 75%???
And finally: how much spooge 1) none, 2) little, 3) medium, 4) lots: 2
9 hours ago, OneLung said:
Year: 1999
Model : KX250
Slide: #7
Main jet: 155
Pilot Jet: 45
Head mod: stock
have you thought about trying a suzuki needle ?
I haven't. What would that do for me and what else would I have to change to be tuned. I feel like the bike does run pretty good. But I'm always open to new ideas and suggestions.
cleans up the bottom end and makes bike lug down low really well
your pilot and main would be good
Ok that sounds like fun. What needle are we talking about and what clip position should I start at?
temps and elevation ?
summer and winter
summer and winter
Winter 50 F
Summer 90 F
0-800 ft
Thanks!
45 pilot
65-90  nedj clip 2
below 65 necj clip 3
your main should be good
18 minutes ago, MudBug20 said:
Will the zuki needle mod work on a 01?
definately
read my post above
i will post part numbers for needles soon
definately
read my post above
Awesome, thanks man
