2014 CRF250R water leak after rebuild
Hi Guys,
Just finish to rebuild my top engine and also rebuild my water pump with the following kit-
http://www.ebay.com/itm/Water-Pump-Repair-Kit-Honda-CRF-250-R-2010-2016-Gasket-Bearing-Mechanical-Seal-/391775546606?hash=item5b37a46cee:g:sdwAAOSw8vZXMfa9
(as you can see, it's without the shaft)
So after finishing all up, I ride for 1 hour and than water start leak from the weep hole.
Review some previous posts and saw that there is an issue with the mechanical seal that can also cause that, still didn't understood what is the best homemade to push it in?
Thanks
Nope, found that I assembled the seal upside down
Edited by IdanBu
Hey at least you'll never make that mistake again! Good job on finding it!
