93 cr125 transmission problems
I bought a 1993 cr125 with a heat seized piston and ended up with much more trouble than I anticipated. Top end is rebuilt, cylinder is all squared away. I took it for it's maiden voyage and found that I only had the first 3 gears. When I went to shift into 4th it felt like I was hitting something very solid with my shifter. The clutch plates are in spec but the springs are .050" long. Can anyone help me?
Take your basket off first and inspect the shift mechanism, segment and pawls. If not any of those it's probably got a bent fork or I've seen pinion gears weld thierselfs to shafts if run low on oil. Or bad spot in shift drum. Like I always say . Stuck in gear or not shifting is better than slipping in gear. Usually just a couple parts. Slipping can get costly
