Starting in gear
After stalling my bike at stop light.   Can't start it in gear only in neutral. Read the manual.  Said it will start it in gear with clutch in and kickstand up.  Can anyone help out.
Thanks
Possibly broken switch at the clutch lever. I would do the continuity test as the service manual says and go from there.
Thanks
most likely the plug at the clutch lever came loose .... push it in and it should be fine. This happened to me once.  If not then you'll need to be more thorough. If it was your kick stand it would die when put in gear.
  • Like 3
