250 right case cover
Long story short...this ones mine now '01 DR-Z250
Any tips on pulling the right side case cover off...or putting it back on? Hondas come off really easy...but are tricky to put back on. I need to inspect the clutchs and what ever else I can see.
FYI...case isn't cracked...that I have found yet...I did find the electrical tape that was being used to wedge a bolt into the oil drain...
Cover came off really easy. and...after all this motor has been through...the clutch looked really good and everything was still within spec. Got lucky on that one. Valves are next...
Finally had time to check the valves...Intake spec is .0039in-.0079in...I can get the .003in in but not a .004. soooooo what does that mean??? am I good??? Is it bad that they are on the tight side?
And FYI....no indications that the motor was over heated or run dry...from what I have seen so far, but it does have a load tap at idle once it comes off the choke. timing is good...waiting for the gaskets before I check the chain tension/tensioner...
