Led light problems!
So i just got a 1x6 led light bar from walmart and rigged it up to my 92 xt 350. I have a 3 point on off switch with 2 wires coming straight from the battery and the 1 hot wire coming from the led light. It works flawlessly, except my battery isntantly got drained. Also when my turn signals are activates instead of flashing they just stay lit. What do i need to do?
Your new light draws too much power. Your XT was designed to have the headlight run on AC and the battery/DC circuit supply the horn, tail light and turn signals. You'd need (if it is posible to get, a high output stator, a larger regulator/rectifier and convert the bike to be fully DC. Contact a company like Ricjky Stator and see if they have the parts. Plan pon spend a few hundred at a minimum and be prepared to do some rewiriing.
