Rebound check valve
I'm fitting gold valves to my 2000 wr400
RT recommends that a check plate be fitted to the rebound valve. Many years ago I had the forks revalved but they were never any good. When I pulled the rebound apart I had to use a razor blade to take off the valve shims as they were loctighted together ?.
My question is - has the tuner already fitted a check valve to the rebound valve? You can see a shim under the spring and cupped washer, pic as removed from cartridge.
Cheers
