Does this cam look damaged
Does this cam look damaged? I bought a used one online but can't tell if it's good or bad. The right side doesn't feel perfectly smooth but yet it  doesn't feel scratched either. IMG_20170604_105313808.jpg.494413c60ce0ff260f283c01b437211a.jpg
Yes it looks like it was run with dirty oil, but not oil starved, or it would have turned blue/black.
If you can catch your fingernail on the ridges, I would say it's worn out.
You could take off the high spots and then mic it to see if it is useable.....but I would just get a refund.
unrelated question but is it ok to have an engine run with different materials for the intake valves? like 2 titanium and one stainless?
It's a bad idea. Stainless valves use heavier spring kits.
once a steel valve has been installed can I replace it with a titanium one or does the valve seat need to be machined for the titanium one
Anytime you fit new valves you need the seats cut to ensure it seals properly
It doesn't look too bad. If you can't feel it with your finger nail it should be ok however pictures can be deceiving.
That's what my ex wife said...
Ok, is there a difference between stainless steel and titanium valve guides? The ones I have fit but I just swapped one valve from stainless to titanium and idk if they have different guides. And yes I did use the titanium spring.
They don't make titanium valve guides.
I'm trying to choose a antifreeze, all I know is that some pink stuff was in there before. I would like to know if this is safe to use for 04 we. As the manual only said 50/50 for aluminum and anti corrosion. I couldn't really find anything specific online and I'd hate to screw up the rebuild on the last thing I need to do.
So I started it up for the first time after doing the rebuild. It started on the first kick and idled beautifully for a bit with the choke on. Once I turned the choke off it died immediately and now I can't get it started again. I've checked everything on this bike 100 times and the only thing I can think of was the air fuel mixture? but it ran with that jetting previously and I don't think that should prevent it from running? When I kick it I can hear it turning over like it wants to go but it just sputters and doesn't start. There was a lot of white smoke coming off the radiator but I think that was due to me previously spilling antifreeze and gasoline all over it from a few mishaps/eruptions. I'm afraid to start it again due to fear of causing internal damage, what should I do?
Clear the cylinder (kick through with the kill button held down and the throttle wide open) several time, and start it again, with the choke. Do not turn it of for at least a minute.
Turn the idle screw in while its warming up, to get a too-high idle.
Then push the choke back in. If it will not idle, you have a contaminated pilot circuit. The jet, the passage above the jet, the fuel screw, the fuel screw oring, or the body seal (meh) needs attention. Typically, the passage above the pilot is partially clogged due to a very sharp bend. Use solvent and fine wire to clear it out.
Ok I'll give it a try, I recently cleaned it but it hates me so maybe it clogged again. Thanks for putting up with all my annoying posts.
As described, your symptom is the pilot circuit.
That could be the passage, the jet, the fuel screw passage, the fuel screw oring, or god forbid, the body seal.
How many rpms would be the goal for the idle screw? I have set for 4k with the choke on but It doesn't sound healthy going any higher for idle.
