dead battery, alternator? regulator? saddnes
Hey, i have problem with alternator or regulator i believe. At the beginning of this year i bought a new battery thats why im sure its fine. Today i had problem with ignition so i removed battery and checked charge level, it was empty. DRZ is my commute bike i ride everyday so i guess battery should be full charged if everything works fine. So here is question how can i check alternator and regulator efficiency. What values should apear when everything works? What wires are required to make a test? Thanks for any respond i hope you guys can understand what i wrote.
Follow the troubleshooting guide in 'free power mod' step by step.
 Then do the free power mod itself , it should free an extra 1 volt to keep the battery alive.
it seems like my stator is almost dead, i got 0.3V to 0.6V after giving some throtle. Checked also regulator and its fine one direction current flow.
