Rough sweeping corners
Weight the outside peg pretty much wanna sit on side of seat keeping your weight over the shock.  It's something that comes with time racing and getting faster. I've always liked a rut or even just a little lip to slam off. Go to your local flat track race check out A class you can learn alot about corners like that maybe :thumbsup:
A lot of times when sections get as you describe, a little higher up on the berm is a much smoother line. A little more speed, a little more lean, ride higher on the berm and you may find that to be the best/easiest line through such a section.
I once had a person tell me " I though you were going to go off the track, then I realized what you were doing". LoL
